 Problem with paint (Royal purple Vallejo)
PostSubject: Problem with paint (Royal purple Vallejo)   Thu 18 Dec 2008 - 15:36
I use always Vallejo paints, but I have problem with royal purple.
It looks like it was there a very thick paint and water. I can make it better (by shaking) and use the paint normally, but after that, it turns to "stone and water" again.
I wouldn't ask, but I have this problem only with Royal purple (I bought it first a year ago, and yesterday the second one - so it isn't only one paint)- once I thought it doesn't depend on the color, but maybe it does?
Maybe there is any way to make it useful without shaking 10 minutes everytime I use it?
It's annoying Mad
PostSubject: Re: Problem with paint (Royal purple Vallejo)   Thu 18 Dec 2008 - 18:00
I use different paints from time to time and i have a certain brand and color that does it as well. I asked around and was told to put a small steel marble in it and shake it with that. Does not take as long and seems to work somewhat better that shaking for the ten minutes routine.
Not sure if you want to try it, but thats how i handled that situation.
PostSubject: Re: Problem with paint (Royal purple Vallejo)   Thu 18 Dec 2008 - 23:00
Acrylic paints, like oil based paints, tend to dry glossy. To achieve a matte effect, talc is added to the base, which is why the water has an oily appearance. Some colors, usually dark blues & purples have a tendency NOT to accept the talc. The little steel ball [BB shot for an air gun works well] is an EXCELLENT method of achieving a good mix; it's the method used with matte spray finishes, which is why you get that rattling sound when you shake a can of matte finish & you don't with a gloss. Suspect thumbsup
I CAN hardly wait to see what you are doing up in Purple! cheers
PostSubject: Re: Problem with paint (Royal purple Vallejo)   Fri 19 Dec 2008 - 3:43
Deaf, you know everything. What would we do without you?
PostSubject: Re: Problem with paint (Royal purple Vallejo)   Fri 19 Dec 2008 - 3:49
lol! You'd MOST probably do very well. I know I have as little to do with me as possible. Suspect
ACTUALLY my mind, such as it is, ONLY retains information of dubious worth; practical information is IMMEDIATELY discarded.
PostSubject: Re: Problem with paint (Royal purple Vallejo)   Fri 19 Dec 2008 - 7:40
Oh, Nala! I love you
Thank you! You saved my life Very Happy
Well at least my left hand Wink
PostSubject: Re: Problem with paint (Royal purple Vallejo)   Fri 19 Dec 2008 - 11:51
You're welcome. It IS a very nice hand; I'm SURE you 're attached to it. Suspect thumbsup
Burlok Blackaxe
PostSubject: Re: Problem with paint (Royal purple Vallejo)   Sat 20 Dec 2008 - 0:30
Like it was said above, just stick an agitator in your paint pot so you don't get it separating like that again.
Lord Xi
PostSubject: Re: Problem with paint (Royal purple Vallejo)   Sat 20 Dec 2008 - 10:16
Agreed. What if I could only replace all the rubbish with practical learnings...
But then life would be less fun.
PostSubject: Re: Problem with paint (Royal purple Vallejo)   Sun 21 Dec 2008 - 22:19
Awesome! I've had the same problem with my Vallejo paints. Blue, purple and some of the cooler browns. DeafNala you rule! sunny
PostSubject: Re: Problem with paint (Royal purple Vallejo)   Mon 22 Dec 2008 - 3:44
Oh yes!
I tried what you said, Nala, and IT WORKS! cheers
PostSubject: Re: Problem with paint (Royal purple Vallejo)   Mon 22 Dec 2008 - 3:49
Thanks for letting me sneak in a cherished, but REALLY bad pun! Suspect
» Smokebush Cotinus coggygria 'Royal Purple'
» Purple Smokebush
» Question: Chipped Paint?
» power transformer problem - help?
» Malta's Hurricane Mk.IIC - looking for photo & paint scheme
