| Orc Shaman - Need Help with WIP | |
+6StyrofoamKing magokiron Von Kurst Identity catferret PitFighterTrainer 10 posters |
PitFighterTrainer Ancient
Posts : 414 Trading Reputation : 4 Join date : 2009-01-19 Location : Houston, TX
Personal Info Primary Warband played: Pit Fighters (Unofficial) Achievements earned: none
| Subject: Orc Shaman - Need Help with WIP Thu 19 Feb 2009 - 2:30 | |
| I am needing to convert an Orc Shaman, as I have not had any luck with finding a suitable model for trade. I did receive some bits and such, and put together a rough idea of an orc shaman. The pieces are glued, barely, and able to be removed and reapplied if necessary. Question is, what can I do to make this model more shamanistic WITHOUT GreenStuff? Here is the model as it stands... The cape does look a little too small, and I was thinking of switching that one out with a Chaos Marauders/Chaos Warriors cape, that is half a cape, and looks like stitched together pieces of hide. Any ideas? Or does this model look 'shamanistic' enough? | |
catferret Venerable Ancient
Posts : 508 Trading Reputation : 0 Join date : 2008-08-10
Personal Info Primary Warband played: Orcs & Goblins Achievements earned:
| Subject: Re: Orc Shaman - Need Help with WIP Thu 19 Feb 2009 - 2:43 | |
| I think that if you swapped out the cape for a bigger one (the small one looks too "tacked on" rather than looking part of the model) and added a wolf head or similar on top of the orc head that would really help. No GS required, just get a plastic wolf or Chaos hound and cut off the lower jaw. Obviously, GS would help fill any gaps but you may get away with it if you cut the parts precisely enough with your knife.
Aside from that, I would say the model is certainly very close to completion.
EDIT: A Chaos Warrior cloak may be a suitable size actually. It would take a fair bit of trimming to remove the parst of the torso that are attached, but I think it would work. | |
Identity Elder
Posts : 368 Trading Reputation : -2 Join date : 2009-01-14 Location : California
Personal Info Primary Warband played: Lizardmen (Unofficial) Achievements earned: none
| Subject: Re: Orc Shaman - Need Help with WIP Thu 19 Feb 2009 - 3:10 | |
| If you have spare bits around, you could glue some pieces hanging from the spear lashing. You already have severed heads, so other ideas might be shamany bangles, bones, skulls, tusks, etc. | |
| Subject: Re: Orc Shaman - Need Help with WIP Thu 19 Feb 2009 - 3:26 | |
| I have a hard time getting past the pose. Its dynamic but it looks like he's going to fall over. A different cloak might help this. Otherwise I echo the call for gubbinz on the spear. js | |
| Subject: Re: Orc Shaman - Need Help with WIP Thu 19 Feb 2009 - 6:09 | |
Guest Guest
| Subject: Re: Orc Shaman - Need Help with WIP Thu 19 Feb 2009 - 8:10 | |
| I'd say use the first cloak to make a sculpy mold and the make a greenstuff cloak that would form to the pose better.
Step 1: Buy a pack of Super Sculpy Step 2: Press the detailed side of the cloak into a slab of the super sculpy an remove it gently. This is your mold. Step 3: Bake the super sculpy. Step 4: After the mold has cooled take a cloak sized piece of greenstuff, wet it, and press it into the mold. then quickly remove the GS. It is good to leave a bit of excess GS exposed from the mold for grip and easy removal, then just cut off the grip afterward. Step 5: Attach the cloak to yur model and use wet utensils to pose it.
Let the GS harden and your set.
I hope this helps. |
magokiron Ancient
Posts : 410 Trading Reputation : 0 Join date : 2009-01-06 Location : Mexico City
| Subject: Re: Orc Shaman - Need Help with WIP Thu 19 Feb 2009 - 8:35 | |
| IMHO the goblin familiar/book carrier is sooo cool as to be obscured by the severed heads.
BTW, Where is that model from?
Thanks. | |
Identity Elder
| Subject: Re: Orc Shaman - Need Help with WIP Thu 19 Feb 2009 - 8:52 | |
| Wow, much improved in my opinion! The goblin familiar is fabulous; it is a bit of a shame he's somewhat obscured. I know you said no greenstuff, but if there's any way you can fill the gap between the cloak and the wolf head, it'd look a lot more realistic. | |
StyrofoamKing Etheral
Posts : 1355 Trading Reputation : 0 Join date : 2008-02-16 Age : 39 Location : Chantilly, DC
Personal Info Primary Warband played: Pirates (Unofficial) Achievements earned: None
| Subject: Re: Orc Shaman - Need Help with WIP Fri 20 Feb 2009 - 5:21 | |
| Goblin my eye! that's a Snot familiar!
I think it was Kurgan who also added a few 'feral' touches to his orc pirates using Beastman bits. For example, braids of hair. Oh, and a picky thing... your cloak seems to be flying back in the wind, while the heads a pointed straight down. Personally, I like to have all hanging items tilted in the same direction, or not tilted at all... Or, if you really want to, twist the feet on the shaman and actually have him moving forward, thus the cape is rippling as he walks. | |
| Subject: Re: Orc Shaman - Need Help with WIP Fri 20 Feb 2009 - 5:52 | |
| Snot, never heard of it. But I don't doubt you at all, as this is my first foray into Orcs and Goblins. | |
| Subject: Re: Orc Shaman - Need Help with WIP Fri 20 Feb 2009 - 6:28 | |
| Snot as in Snotling. I think the figure comes with the Night Goblin fanatics box.
Umm... the shaman is moving forward, or perhaps to the side. The severed heads being a bit more weighty than the cloak would account for their angle...
I like this incarnation much better than the first. js | |
Unwanted Warlord
Posts : 219 Trading Reputation : 0 Join date : 2008-07-15 Location : K-Town
| Subject: Re: Orc Shaman - Need Help with WIP Fri 20 Feb 2009 - 10:06 | |
| The wolf-head adds a lot to the Shamanistic quality you were looking for. Kudos on that. As for greenstuffing the gap, go for it! Greenstuffing to fill gaps is easy, making furry greenstuff is easy, hence filling a gap with furry greenstuff is double easy | |
| Subject: Re: Orc Shaman - Need Help with WIP Fri 20 Feb 2009 - 10:20 | |
| WOW! That's coming along nicely, AND quickly to boot. The Snotling Apprentice IS a VERY cool little touch. WELL DONE! Keep taking all the fine advice & posting you progress. | |
Ethlorien Ancient
Posts : 475 Trading Reputation : 0 Join date : 2008-09-04 Age : 43 Location : Calgary, AB
Personal Info Primary Warband played: Marauders (BTB) Achievements earned:
| Subject: Re: Orc Shaman - Need Help with WIP Fri 20 Feb 2009 - 15:10 | |
| That fellow is looking great - personally I think he's done. Very nice. | |
| Subject: Re: Orc Shaman - Need Help with WIP Fri 20 Feb 2009 - 16:21 | |
| I tore off the cloak, and had no green stuff to work with, so I cheated. I got ANOTHER cloak, the ones with the chaos marauders set? It has a fur top near the shoulders, then a skull in the center, and the rest of the cloak is smoothed out. I cut away the furry section of the cloak, dug out the wolf head a little more to fit better, and to remove the excess near the back of the head that meets the cloak. THEN, I put the cloak in three pieces. Wolf Head, then the newly cutoff fur section, and last, the fur cloak. It looks somewhat better, but I had to keep removing it, and putting it in a viable position to look somewhat more natural.
I removed the left arm, with the heads, as it WAS detering the snotling from being viewed properly. I then replaced that arm with a hand holding a dagger ready to strike. This served the double purpose of hiding the section of the cloak/wolf head that was a gap.
Lastly, I then removed the dangling hair ornament from the spear, cut off the hair from the center ball piece, and put it back on in a manner that would match the cloak's placement of looking like it was blowing in the wind. It is not as pronounced as the cloak, in displacement of the wind, as the center ball piece would weight it down more, IMHO.
I will take some pics when I get back home, as I am in the office now, back to the grind. I like the new shaman look, and hope it can get painted sometime soon. I am still not up to par on paints, as I don't have much of anything left. Anyone want to trade mini's for paints??? | |
| Subject: Re: Orc Shaman - Need Help with WIP Sun 22 Feb 2009 - 20:40 | |
| Ok, redid the cloak, using Sculpey and checking to see how best to dry it out now. Check out the new Orc Shaman! I can't get this File Uploader to work, so you will have to go to the YOCs site to view it. ORC SHAMAN | |
| Subject: Re: Orc Shaman - Need Help with WIP Sun 22 Feb 2009 - 21:25 | |
| Now it's looking great! With the wolf legs hanging down, the cloak really looks part of the model now. Good stuff. | |
CrazyOrc88 Champion
Posts : 49 Trading Reputation : 0 Join date : 2008-10-06 Location : New York City
| Subject: Re: Orc Shaman - Need Help with WIP Sat 7 Mar 2009 - 2:58 | |
| To be perfectly honest here, the first pics you had up looked nothing at all like a shaman, except for the snotling on the base. However, your most recent pictures look excellent as a shaman, either as an orc or savage orc shaman. Either you got very good at conversion ideas and cutting very quickly, or you just weren't applying yourself in the beginning. With a good paintjob and some warpaint possibly this will look very very good. | |
| Subject: Re: Orc Shaman - Need Help with WIP Sat 7 Mar 2009 - 5:22 | |
| Thanks! I have redone the model, removing the Sculpey, and replacing with Green Stuff. Unfortunately, this GS is not as workable as the Sculpey was, and it didn't come out as well as I had hoped. Apparently, GS needs to be done in stages. I added another layer, and this one allowed me to do the finer details that I like in a cloak. I also got a dremel tool, so that I was able to modify the feet, stance, and clean up some imperfections with glue. Also, the cloak is longer. More pics are on the LINK: Orc Shaman WIP Site | |
| Subject: Re: Orc Shaman - Need Help with WIP Sat 7 Mar 2009 - 8:13 | |
| WOW! That IS an incredible change for the better. The new Wolf Cloak is Fantastic; the forelegs dangling dow in front REALLY make it feral looking, Orc Chic. A VERY unique, in character piece, AND VERY WELL DONE! | |
| Subject: Re: Orc Shaman - Need Help with WIP | |
