 Water-skaven test piece
KupoFIN
PostSubject: Water-skaven test piece   Sun 11 Aug 2013 - 13:55
Hi,
some time ago I was reading a blogpost at Liber malefic that teased the available warbands of upcoming Mutiny in Marienburg supplement. One of these, stoats/skroats, caught my attention. While I found absolutely NO fluff about them, aquatic skaven are not that farfetched idea when you think about it. So I thought to make a test model.
Essentially it's just a skaven wading on a themed water base. However, if the stoats/skroats (which ones are they anyway??) prove to be an interesting warband, I migh juat build one, as an ex-WHFB skaven player I still have some skaven minis lying around.
TL:DR: my stoat / skroat / water skaven test model:
C&C's are wanted!
PostSubject: Re: Water-skaven test piece   Tue 13 Aug 2013 - 19:05
I have no idea what it should be called, but I like what you have done with the model. As a basing style it could work for any skaven warband given a swamp or sewer theme.
Where exactly did you see the reference?
KupoFIN
PostSubject: Re: Water-skaven test piece   Wed 14 Aug 2013 - 8:40
PostSubject: Re: Water-skaven test piece   Wed 14 Aug 2013 - 9:45
I'm not sure what Werekin has going with his Mutiny in Marienberg project, but a Band of Wharf Rats seem like they might fit in nicely. Your test model looks SPLENDID. I'll look forward to further developments.  thumbsup
PostSubject: Re: Water-skaven test piece   Wed 14 Aug 2013 - 11:56
Just because there might be a prank involved doesn't mean, you couldn't write up a Wharf-Rats Warband yourself, if you like the mini. Or you could make werekin feel guilty enough to add a rat-list to his Mutiny-Campaign for getting your hopes up in the first place. Very Happy
werekin
PostSubject: Re: Water-skaven test piece   Thu 15 Aug 2013 - 5:18
There was some truth to it... If you're playing pirate-rats in a campaign then all you need to do is PM me about the Clan Skurvy alliance.
Regards,
Werekin
» Majolica Owl Jug - test piece?
» Water to run our engines
» Water pump
» Burrell 4" - help required re getting water from tank to boiler
» 4" water bowser\cart
