 Using Flight of Zimmeran to Charge a target that is unseen
aviphysics
PostSubject: Using Flight of Zimmeran to Charge a target that is unseen   Wed 8 Feb 2012 - 13:25
The question is simple. Does a model have to make an initiative check to charge an unseen (not hidden but behind a wall or whatever) with Flight of Zimmeran?
PostSubject: Re: Using Flight of Zimmeran to Charge a target that is unseen   Wed 8 Feb 2012 - 13:54
No, because you are not charging.
You are moving magically and you count as charger if you get into contact with an enemy.
PostSubject: Re: Using Flight of Zimmeran to Charge a target that is unseen   Thu 9 Feb 2012 - 0:44
Actually, it says that you count as charging. This can be understood in two ways, and I have not seen any FAQ resolving it:
1) The magically moving sorcerer counts as having charged. In other words, the charge cannot fail, since it's already done.
2) You count as charging, meaning that if you can move the model into contact you're in cc, but will still have to take fear tests, initiative tests and the like.
In my group we've gone with 2) in the one case it has been an issue.
» Medieval Village at Target
» Jack Sparrow was sighted in Target
» Top Flight Schoolboy/ Cox TD .020
» The flight before Christmas:Ace littlest stick powered by throttled Cox teedee 051
» Drabble Collection (FFXIII, FLight)
