 Need help finding modified weapon critical hit tables.
TheMuumio
PostSubject: Need help finding modified weapon critical hit tables.   Fri 30 Jul 2010 - 6:24
So I recall seeing a modifed table that included every (or most) weapon(s) with each having it's own critical hit table. Me and my friends got bored of the critical hit tables from the back of the book do to them being too illogical (dagger doing as much damage as a 2-hander) and I remembered someone having made a PDF that had a new critical hit table (along with some other house rules).
So i am asking you to help me find the crit table. I am sure it was posted here.
Actually, I'd like you to link to every alternate weapon specific tables you can remember.
Thank you.
Ps. Tried using the search but it doesn't give real results.
toemasss
PostSubject: Re: Need help finding modified weapon critical hit tables.   Sat 31 Jul 2010 - 3:10
TheMuumio
PostSubject: Re: Need help finding modified weapon critical hit tables.   Sat 31 Jul 2010 - 3:14
toemasss wrote:
Is this what you were after?
http://mordheimer.com/optional_rules/adv_crit_tables.htm
I'm sure that it was not that - I recall seeing the table being weapon specific (ie. 2 handed weapons have different than daggers or swords etc).
This however is better than the one in book and if I can't find the one I'm looking for we will probably use this. Thanks.
sartori
PostSubject: Re: Need help finding modified weapon critical hit tables.   Tue 3 Aug 2010 - 23:47
We are trying these out:
http://home.comcast.net/~sartori30/mordheim/mordheimexperimentalcriticalcharts.pdf
So far we are liking it, but I have to warn you it can be quite a bit more brutal than the standard table. Also, some of the results ask for additional die rolls. The "max of +3 to injury rolls" makes it so that there is always a chance no matter what of rolling a stun, but it is a house rule.
» Conversion & Ingredient Tables
» Critical hits easy fix (?)
» z-28 cluster modified for Roadmaster
» Here is my heavily modified st120
» Bonsai stands and tables
