 Help required with feathers
Lord 0
PostSubject: Help required with feathers   Sat 3 Apr 2010 - 6:15
I have a Beastmen warband that has two eagle-headed beastmen for heroes. Now, painting the eagle-heads will be easy - I can paint feathers when they are sculpted on. The thing is though, the skin is smooth. What is the best/easiest way to paint something that will give the impression of feathered arms and torso?
squattingmouse
PostSubject: Re: Help required with feathers   Sat 3 Apr 2010 - 6:32
How about gently drybrushing a slightly darker/lighter shade over it in streaks to give an impression of feather edges all pointing in one direction?
Lord 0
PostSubject: Re: Help required with feathers   Sat 3 Apr 2010 - 6:33
Not quite sure what you mean. Do you have an example? Which way should the lines be going? Horizontally? Vertically?
For reference, I am a *very* amature painter. I know what drybrushing is, and I know what washing is, but beyond that I have very little skill or knowledge. I have heard *of* things like non-metallic metallic and that light-source thingy painting, but I wouldn't have a clue how to do it.
CygnusMaximus
PostSubject: Re: Help required with feathers   Sat 3 Apr 2010 - 8:24
You could try stippling it with a lighter colour to make it look more like down feathers. Just take an old brush, put a little paint on it (so that there's a bit more than you'd have when drybrushing) and "stab" at the model as if the bristles of the brush were a... stabby thing. This is a fairly easy technique that might get you the results you're after.
I think you should have a go at sculpting some feathers yourself, but that's mostly because I have a similar project that I'm putting off because I don't think I could sculpt a convincing feather to save my life!
» Help wif arcane feathers
» Helix fossil or omanyte seriously required
» Burrell 4" - help required re getting water from tank to boiler
» id help required for vase marked 1180- German?
» 110v or 220v power output.
