 Water Bases?
5 posters
jackanory
jackanory
Water Bases? Empty
PostSubject: Water Bases?   Water Bases? Icon_minitimeThu 27 Nov 2008 - 11:38
Does anyone know how to make those cutaway water bases where some of the base is underwater but with a bit of cross-section? Like this one (it's got a naked lady so I've spoilered it...never know who you'll offend! Sorry it was the only example I could find on CMON):
Spoiler:
I'm guessing you have to make some sort of mold and then pour the water effect into that but how o you make the mold?
Water Bases? Empty
PostSubject: Re: Water Bases?   Water Bases? Icon_minitimeThu 27 Nov 2008 - 11:47
I read somewhere how to do this kind of things... I suppose it was either in an issue of WD or in the Scenery & Terrain guide of GW... I'll see if I can find it (and find the time to look for it)
Water Bases? Empty
PostSubject: Re: Water Bases?   Water Bases? Icon_minitimeThu 27 Nov 2008 - 11:57
I like this example:
Water Bases? Duel
jackanory
jackanory
Water Bases? Empty
PostSubject: Re: Water Bases?   Water Bases? Icon_minitimeThu 27 Nov 2008 - 13:36
oh man that's so good! Very Happy
Water Bases? Empty
PostSubject: Re: Water Bases?   Water Bases? Icon_minitimeThu 27 Nov 2008 - 13:45
Oh wow, brilliantly done!
on the making of... you would need to make a mold (case around your painted model) with SMOOTH SOLID surface, to avoid the material to stick to it., then you pour your water effect in, layer by layer (be aware of shrinkage) when you are happy with the level of the water, remove the mold et voila.
http://www.mysthconcepts.nl
catferret
catferret
Water Bases? Empty
PostSubject: Re: Water Bases?   Water Bases? Icon_minitimeThu 27 Nov 2008 - 14:14
Those models used clear resin, not water effect. It dries very differently although application is done the way described already.
jackanory
jackanory
Water Bases? Empty
PostSubject: Re: Water Bases?   Water Bases? Icon_minitimeThu 27 Nov 2008 - 14:19
could you put vaseline or something on the inside of the mould as well?
jackanory
jackanory
Water Bases? Empty
PostSubject: Re: Water Bases?   Water Bases? Icon_minitimeThu 27 Nov 2008 - 14:33
Sorry for the double post but I actually found a tutorial here that seems pretty sound that resulted in this beauty!
Water Bases? DSC_0220
Water Bases? Empty
Water Bases?
» Blessed Water:
» Deformed hardened resin
» Scenario - The thing in the water!
» Blessed Water--Who can use/who's affected?
» Finished Water Garden
